Hi guys,
I’m a keen mountain biker and I’m getting fed up of the bushings in my rear shock wearing rapidly. Well, I don’t mind them wearing but they are quite expensive! This got me thinking, why not just make some myself and keep a bunch in the drawer so I can swap them out as needed?
So my question is, what to make them from?
The existing ones on my bike are a plastic bushing that is pressed into the shock with an aluminium shaft running through it. I have seen some people run a brass shaft (I’d probably prefer bronze myself) through a plastic bush but is there any merit in running two bearing materials against each other?
The ultimate aim would be to reduce friction as the difference can be noticeable when out on the bike (I used to run needle bearings but these seemed to come out of the box with a little play which worsened rapidly. they did make the suspension much more supple though).
I was thinking a plastic DU bush and a bronze shaft but if there won’t be any improvement over a steel shaft then I won’t bother with the added expense. I was thinking D2 tool steel hardened to somewhere around the 52 HRC mark if not bronze.
Any help would be greatly appreciated!
