- Jan 11, 2013
- 1,821
I got this three jaw chuck on EBay a while ago, and have finally gotten my Heavy Ten running again, and down to making a backplate for it.
It only says:
PUTr - M 6 1/4 ZD
No 215
It appears to be a pretty sweet chuck, with two piece reversible jaws and smooth action. The closest I can get Googling seems to be almost exactly the same as a Buck B2063R.
My three questions-
1) What are the two holes in the front at 180 degrees from each other for? They go all the way through. In the back there 6 bolt holes, two of which are the two at 180 deg I mentioned.
2) Buck's site says their chuck is "Adjust Tru". How can I tell if mine is also? Do I need to make a different type of backplate to take advantage of this? Or buy one?
3) should I just make the standard backplate I am half- finished with? Hah hah
Pics below...
Bernie
The two countersunk holes straight through- for mounting on rotary table?
Two of these six holes are the countersunk holes 180 degrees from front:
It only says:
PUTr - M 6 1/4 ZD
No 215
My three questions-
Pics below...
Bernie
