Machine Mobility Solution
John_Dennis
Mar 5, 2014
381
I have a very small garage that I share with my wife's car. This means that some of my machines need to move in order to use them. My solution is to put 2 heavy duty wheels on the back side if each machine and use a handle with wheels to lift and steer the front. The drill press wheels are attached to the base using the existing column bolt holes. I used scrap metal brackets from a German X-Ray machine that was delivered to a local hospital. Multi million dollar imaging equipment is well packaged. The two wheel dolly will work for all of my machines except the lathe. It easily moves my 400 pound drill press.
IMG_1750.jpg Shipping support bracket
IMG_1752.jpg Cut end off using large hole saw and band saw
IMG_1755.jpg plates fit around column and are strengthened bu two pieces of 1 inch square tube, also from X-ray crate.
That looks like a better way of moving the heavy items. I think the mobile bases have to small of wheels for heavy items. I will have to borrow the idea for some of my tools. Might even make my own steel spoked wheels for older machines.
Jack
