- Dec 6, 2012
- 2,682
I've had good luck with machine skates. It takes forever to get it lifted 1/8inch at a time, then do the other side, one at a time.
The rollers we used in Indiana were 1/2inch.
If you use a tow truck be sure that the rig has controlled pay - out. As not all of them do.
The other factor is that while tow drivers have huge experience moving big and heavy things, the driver might not be experienced with lathes/mills/grinders which don't necessarily have a low center of gravity.
Consider always lowering knees, rotating heads, removing motors, etc. Anything to move the weight to the base of the item. And yes things can change in a flash.
Don't try to catch it as it rolls!!
Hiring a rigger, while expensive can be much less expensive than scraping you machine, or the injuries etc.
Daryl
Daryl
