- Apr 23, 2013
- 1,015
You can do the trig and cut it manually using an insert with a larger nose radius (or grind it a little larger). Finishing is going to have to be done anyway.
You can make a form tool to do the work also. finishing still required.
Thanks for the reply. I like the simplicity and robustness of your design. It looks easy to make discs for various size ranges or even dedicated sizes which I would consider. The issue of no cutting speed at the centre did not affect the performance of your fixture which is helpful to know.
I may consider a radiused die sinking cutter which will also cut at the back when the tool travels past the centre.
I will email you later for better images if that is ok.
When I first thought up this tool up and posted the hand drawn pic seen in my screenshot Answer to parlo’s postThanks for the reply. I like the simplicity and robustness of your design. It looks easy to make discs for various size ranges or even dedicated sizes which I would consider. The issue of no cutting speed at the centre did not affect the performance of your fixture which is helpful to know.
people told me I would first have to rough the cavity with a big drill or roughing tool. So just to see if it would work I went out to my shop and made the part. I
did it on my light duty Logan lathe. I took cuts of about .100 per swing with no roughed out cavity. I had no trouble with chatter or machine stalling. And just using one disk I could change the radius knowing exactly how much stick out
I had by simply checking stick out of tool. If starting out with a 2 inch alum disk
I knew I had a 1 inch radius then you add stick out of tool to come up with new
radius. If tool sticks out of disk 1/4 inch you have a 1 1/4 radius or 2 1/2 ball size.
one important thing is I made the tool on the lathe that I used it on and drilled and reamed holding drill in collet in spindle. That put cutter exactly on center.
the alum disk can be removed and replaced leaving it’s base on centerline of lathe. Took me about 3 hours to make the tool using what I had in stock bin.
email me for more info if needed. Jimatcf@hotmail.com
