- Jan 5, 2014
- 946
So, I've got one of these and I need to turn off the extended hub, bore out the middle to fit a 1.75" shaft and add tapped radial holes for set-screws (not in that order). It seems simple enough. I plan to hold the hub on an indexer to do the set-screw holes, then hold in a 4-Jaw chuck for the rest. I want to avoid gripping the flanges because they are thin. What are some ideas for holding the piece for removing the extended hub and boring, while avoiding marring the teeth?
The tooth notches are about 1/8" wide and the flange is ~0.25" higher than the notch valley or 0.15" higher than the top of the tooth. Just stick some small blocks in there straddling two teeth? The part was not cheap which is why I'm second-guessing myself.
