[4]
Machinist Level
[3]
[10] Like what you see?
TC0853
Active Member
Jan 31, 2016
30
I'm thinking about buying a machinists level. I've never had one, or for that matter never used, or even seen one, except in pictures. Can anyone shed some light on what ones come more highly recommended,and what some can, and cannot accomplish. Also, I understand everybody has their own ideas on dollar worth, but what I might reasonably expect to pay for a decent, or adequate one. Thanx
itsme_Bernie
Jan 11, 2013
1,749
You could spend $50 for a starrett 6 inch level, $100 for #98 12 inch, and $300 for a #199 1/10000 inch super precision level. All depends on your needs to level. Lufkin also made a nice super precision level :)
brav65
Sep 24, 2014
925
I bought a 6" Starrett level new for $110.00. I liked it so much I have since purchased an8", two 12", 15" and have my eye on an 18" and a 4" to complete the set. I have no reasonable use for that many levels other than I am crazy and like well made tools. I have only ever used the 6" to level my lather. Please do not go down the rabbit hole I found as I do not believe it has a bottom:laughing:
middle.road
Actively Learning...
Apr 28, 2014
1,734
Isn't that the truth? That can be applied to so many items in our chosen hobbies that sets your pulse rate racing when you see them.
(Let me tell you about my silly rabbit holes... hehe)
astjp2
Aug 23, 2013
842
I have 2 twelve inch levels, one to measure longitudinally and the other laterally. I used them on my surface plate and I will on my lathe and mill when I get them back together. If you want a shorter level, get a long enough parallel to set it on so you can measure what you want. Think of how you would measure between 8" of ways with a 6" level. Having a straight edge can have many other uses, dang, now I need to buy one. Tim
atlas ten
Active Member
Nov 17, 2014
172
The machinist bench level would be good for more than just machines. I will use mine to level the fridge too. Toolcollectyitus is a bad bug to get. I have it and only cure is more tools.
Jack
Sent from my SGH-I337M using Tapatalk
middle.road
Apr 28, 2014
1,734
Jack
Toolcollectyitus <-- You'd better Trademark that one!
Eddyde
Bronze
Oct 13, 2014
1,480
I bought a used (eBay) 8" VIS brand (made in Poland) for $50, it's accurate to 5 ten thousandths in 10". So far, I used it to level my milll, lathe, surface plate and pool table, Works great! I have also since acquired a Starrett 98-6, haven't used it yet except to check its accuracy.
TommyD
Active Member
Nov 12, 2015
496
I do the same, I may not need the item but it's just too cool to pass up, ESPECIALLY at a good price. My wife is gonna make a mint off my tools when I pass and she has an estate sale. :angel:
Uglydog
Dec 6, 2012
2,352
Has anyone used the Lufkin?
As designed, is it comparable to the 98 or the 199?
Daryl
MN
atlas ten
Active Member
Nov 17, 2014
172
Daryl
MN
I have a lufkin 12" #57. It is only a bench level. More precise than carpenters level.
There is also models #58 with graduation lines. These might be the master level style.
Jack
mksj
Jun 12, 2014
2,119
The Lufkin shown would not be comparable to a 199Z, which is ~10X more sensitive. On a lathe to detect bed twist, probably want a precision level of at least 0.0005"/10" or better. I use a French EDA branded as SPI, which has an accuracy similar to the 199Z. The level viewing chamber is enclosed and quite easy to see. Might also look at VIZ precision levels.
http://www.hobby-machinist.com/threads/starrett-level-help.11735/
itsme_Bernie
Jan 11, 2013
1,749
Daryl
MN
Hey Daryl!
I have owned the Starrett 199 level which was awesome.
I sold it because people want Starrett 199's and it was mint, and I didn't need it to be so pretty.
I got this Lufkin No 59, which would be the Lufkin equivalent, but much harder to find. It works just as amazingly as the Starrett so I am happy!
Bernie
Uglydog
Dec 6, 2012
2,352
I've been opting for Lufkin over Starrett. Guess I will now be watching for a 59...
Daryl
MN
KBeitz
Apr 17, 2018
473
I bought the 12" Starrett years ago... I found it to be a waste of time.
I build textile and woodworking machinery. I make everything adjustable.
It's fun to play with but I sure have not found a reason to put it to use.
[6]
[5] [7]
