I bought one of these mag base gauge holders a few months back. It's a cheaper made in china product probably the same as you would buy from Banggood and similar.
I like the idea of being able to fix the mag base where needed and then move the dial gauge to the right place and lock it all down with one knob. Also I like the idea of fine adjustment to set the dial gauge or indicator just right.
Great idea, too bad it's next to useless.
The mag base works fine, although I doubt the 800Nm force quoted but it does hold well in most situations. The locking mechanism just doesn't hold tight enough and depending on the angles the arms can sag during a measuring session making the entire operation pointless. Finally the fine adjustment is spring loaded but rather weakly so it's impossible to set and repeat any position on the dial.
With that whinge over I'd like to know if the same style of gauge holder from Noga or Starrett or Mitutoyo really do work well. They are 3 times the price of this cheap thing so I want to know if they are worth the price.
Thanks guys.
Thanks guys.
