Makeing a chuck key
dbb-the-bruce
Dave
H-M Lifetime Diamond Member
Feb 28, 2019
499
I'm going to make a simple tee-handle square end chuck key.
I'm wondering if I should harden the square end. I can see arguments for and against doing so.
Thoughts?
-Dave
Hardening kicks it up a notch from being a simple chuck key. I say and this is just my opinion. Its not necessary.
I believe mine are hardened.
RWM
I made a chuck key from a length of square key stock and it is standing up very well. It is as purchased, no heat treatment at all.
Which steel will you be using?
I have made several chuck keys, and use 4140 HT steel. Also, I made one for a dividing head when I was in a hurry (about 30 or so years ago) from key stock; its still being used on a regular basis.
Great answers (all over the place!)
The "which steel" question is probably most appropriate.
I have a choice between drill rod and a something out of a random pile of unknown round stock (chair legs and other odd and ends that came from the guy I got my lathe from).
I also have a heat treating oven, quenching oil, torches etc. So both hardening and tempering would not be difficult.
I imagine (possibly incorrectly) that as long as the bar stock is substantial enough twisting won't be an issue.
I've also got a mill so the flats / square end will be easy.
I'm guessing that the "nuts/screws" in the chuck are hardened - hence the key would get mauled up before damaging them. So in a perfect world, the key end would be hard enough but not harder than the chuck and the shaft would be stiff enough to not twist but not brittle (probably not going to be able to snap it with hand force anyway)
I'm doing this project to try out some process steps before doing trickier stuff. (and I also need a key for this chuck).
Before tempering (drawing) verify that there is NO OIL RESIDUE on the part. The oil will turn color long before the steel does. [The voice of Experience]
Good and timely information for me :cool:
