- Jan 25, 2015
- 2,558
You may have seen my brake line thread, or maybe not.
In a nutshell, I'm planning to make some brake line flaring dies.
But the problem is i can't quite figure out how to do it.
The dies are fairly simple, they look like so:
It's the square block items.
As you can see, it's a hole through the block and then the block is split so you can place the line between them, then it's clamped together and you use a ram to form the flare aginst the 45 degree angle you see at the entrance to the through hole..
The problem I'm having is how to make them.
For example: make one for a 3/16 od line. First thought was to drill/ream a 3/16 through hole and then split the block in half.
Except, I will loose somewhere around 1/16 to 1/8 from the saw so the hole will no longer be 3/16 round. I'll loose (for arguments sake) 1/8 off one of the hole dimensions, meaning it can be 3/16 in one plan but reduced to as much as 1/16 in the plane 90 degrees to the 3/16 portion. That's not going to work because when you clamp them down on the line, it will crush in in one dimension. Not good for vehicle brakes.
I thought maybe make two identical blocks and then split each one offset the blade width. But that means I have to get two items identical in dimension and the cut has to be very precise to make the two halves mate. Off a little bit and it may crush the line or not hold it strong enough.
So I'm at a little bit of a loss to figure out the best (and most efficient) way to build these things.
Suggestions?
Suggestions?
