- Aug 22, 2012
- 4,133
For my vertical slide I was going to use box slides like the gingery versions.
Last night I had a brain fart and wondered if it would be possible to make an assembled dovetail by milling a 45' chamfer on a bar that can be bolted to the main plate (one on each side) then mill the same chamfer down both sides of the slide plate to fit between them. This would be easier than using a dovetail cutter.
Gibs can be added as required.
Anyone see why this wouldnt work?
