I would think with a 4th axis and cnc, you could do this very easily with a slitting saw, or a slitting saw for initial cuts and a mill for final profiling.My thought was to use the 4th axis on my CNC mill. Once the profile of the gear was generated, I would import the model to the CAM program which would generate the tool path to cut the tooth profiles. While this would be slower than hobbing a gear, it could be run automatically without an operator.
One more use for the CNC mill.
DP = 25.4/ModCan somebody tell me a simple way to convert DP to Mod?
