A
Andre
Forum Guest
Register Today
Ever since I got my larger lathe, the little AA 109 just isn't being used anymore and is taking up bench space. I can sell it for $250 or so, it's in darn good shape, so that's my budget. I'm thinking of building a small manual bench lathe to replace the 109. Possibly using fully supported bearing rail in the 12-16mm range, or track. I know a guy who deals with linear bearings often so I will ask his opinion on which to use.
I know a lot of homemade CNC lathes, routers, and mills use linear bearings and track but will they be suitable for a manual machine, where there WILL be backlash in the screws? Because linear bearings feel like they're floating on a magic sheet of anti-friction air I wonder if the carriage will bounce around, without a zero-backlash screw to keep it in place. Any opinions welcome.
