- Apr 30, 2016
- 3
i have an Emco maximat v-13 mounted in the back of my m-944a1 5- ton. I finally got on this forum and found correct wiring diagram to get it running. Turns out the e-stop had been disconnected. After rewiring that so that the main relay would work I can't get it to turn in both directions. I tried unhooking control wires and reconnecting opposite way still no luck. Resistance through the switch tests good for both directions and the lathe runs fine in one direction. Also manually operating the relays will turn it in both directions. Any ideas would be appreciated. It is a 220v 2 phase motor.
