- Dec 26, 2016
- 2,018
We need a bigger mill."Jaws" theme Da Da Da Da
It would be difficult to injure oneself with such a small machine, if it has a 40,000 RPM capable spindle this is a different kettle of fish, no one would spin an unbalanced tool that large at that speed. If you spin a large fly cutter start at the slowest possible spindle speed and increase it if possible.Sometimes it's called maimed or dead. Pushing the envelope is great macho fun until we find the limits, then it's game over -- sometimes permanently.
Using an 8" long tool might give you enough extension to span 12" but there may be enough resonance to make the finish/flatness a problem.
Yea your probably much better to use narrower passes which are smaller as the resonance will probably give an un even surface unless you run at a ridiculously slow rpm.
you could use fine abrasive paper spray mounted to glass after machining to get the last thou or 2 of total flatness.
like that tom does sometimes.
Tom is generally going for "Optically flat" or better than 1 micron.
CorrectYou can spin a fairly large fly cutter as long as you balance it. balance is always the key to spinning large diameter objects. It's also important that the cutter and its extensions are rigid. Your only problem then with a large diameter is to get the speed low enough. Small machines often won't go that slow.
Yeah , when he's says flat he means really really really flat.
