- Jul 15, 2020
- 421
I just purchased an used X-Y table to fit on my drill press for the purpose of locating holes precisely. My bench knee mill lacks the vertical capacity for doing this when the work is over about 6 inches from the top of its vise.
The x-y table turns out to weigh in the neighborhood of 60 lbs. without a vise. The drill press being used has a base, 2 3/4" dia. column, and table from a Delta DP220. It happens to have a head from a Walker Turner. The table is spaced out 1/2" with a steel plate to give it a 15" swing. It does have a table lift mechanism.
Any thoughts on whether the drill press can handle the 60 lb. weight of the X-Y table with a 10 or 15 lb. vise? With the X-Y table, the 15" swing becomes irrelevant, so I could always remove the spacer plate.
