[4]
Metal cutting bandsaw.
[3]
[10] Like what you see?
elewayne
Newbie
May 22, 2018
12
Likes
4
#1
Hi, this is my first post. I have a question. I own a 10" Delta band saw for wood working. I'd like to use it to cut metal. how could I slow down the blade speed. IT has about a 7" pully for the wheel and I can only clear about another inch before it would hit the table. Is there a way to install another shaft to help with speed reduction?
benmychree
John York
Jun 7, 2013
2,737
Likes
1,982
#2
You would need to have an intermediate shaft with suitable pulleys to reduce the speed; the motor pulley would drive a large pulley on the intermediate shaft, and a small pulley also on the intermediate shaft would drive the pulley on the bandsaw shaft, or you could use a worm gearbox to reduce the speed, a separate motor could drive the worm gear and have step pulleys to vary the speed, or use a frequency drive. There would need to be some sort of clutch coupling to disengage the gearbox output from the bandsaw shaft to use the high speeds.
Mitch Alsup
Active Member
Nov 17, 2017
351
Likes
235
#3
You need at least a 10:1 reduction and maybe as much as a 20:1 speed reduction.
Wood gets cut at 1500-3000 fpm while mild steel gets cut at 150 fpm.
benmychree
John York
Jun 7, 2013
2,737
Likes
1,982
#4
The chart on my 20" Rockwell says 150 FPM for thickness under 1/2", 100 FPM for thickness up to 1", and 80 FPM for anything over 1".
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
796
Likes
527
#6
Do you not understand the math or simply how to go about mechanically controlling the speed?
Hawkeye
Jun 17, 2011
1,849
Likes
571
#7
I had a 15:1 gearbox that I added to a 1940s Beaver bandsaw I picked up this winter, along with a couple of triple pulleys. I've got 9 speeds from 28 sfpm to 504 sfpm. I love this saw.
kd4gij
Feb 7, 2011
4,672
Likes
1,846
#8
Some pics of the band saw showing the drive system will help us to help you out.
Kernbigo
Apr 8, 2012
729
Likes
209
#10
Here is my craftsman 3 wheel 10" that i use for wood and metal. I make my own blades from bulk do-all material . I'am running a treadmill motor on it works great no gear box etc. This is the second 1 i did ,the first was a 14" but took up to much room in my small basement shop.
pineyfolks
Apr 30, 2012
1,078
Likes
419
#11
A small lawn tractor transmission might do the trick for you.
Kernbigo
Apr 8, 2012
729
Likes
209
#12
why does everyone think you need a transmission when a simple treadmill motor works great. I have 1 on my band saw and 1 on my south bend lathe/
pineyfolks
Apr 30, 2012
1,078
Likes
419
#13
I use lawn tractor transmissions on several pieces of equipment when I first started my shop because my dad repaired them and we always had them setting around. Now days there are treadmills setting around everywhere. Years ago they weren't that common, we basically just walked on our own.
Eddyde
Bronze
Oct 13, 2014
1,421
Likes
1,208
#14
Because that would be too easy ;)
rwm
Mar 25, 2013
1,494
Likes
1,690
#15
I am curious about that. How is the torque when you are running at 1/20th of full rpm?
Robert
elewayne
Newbie
May 22, 2018
12
Likes
4
#16
I won't be strong on the math either, but I was just looking at the machinacals. Just to be sure I had some idea what to do.. I only want to cut sheet metal on the saw anyway. Not 2" thick bar.
P. Waller
Mar 10, 2018
796
Likes
527
#17
Thin sheet material will be far more difficult then large bars.
rwm
Mar 25, 2013
1,494
Likes
1,690
#18
For Sheet Metal you need really fine teeth. At least 18 TPI. How thin exactly?
Robert
Eddyde
Bronze
Oct 13, 2014
1,421
Likes
1,208
#19
No worries, If you decide to do the conversion I and others will be here to help. It will be very helpful to post some photos of your machine.
Kernbigo
Apr 8, 2012
729
Likes
209
#20
If you want to cut sheet you reverse the blade work like a champ
Sent from my SM-G900V using Tapatalk
Scruffy
Jun 5, 2013
484
Likes
284
#22
Very interesting read. I,m in the very slow process of making a 19 teens hundred horizontal mill into something that is usable.
I,m not restoring this,I want it usable. It was a line shaft machine ,converted to electric very poorly.
Here’s my plan make a mirror image step pulley to give me 4 speed choices. Still way to fast ???? So I,m using a 5 speed motorcycle transmission .
Motor to trans to first set of step pulleys, yep I,m nuts with to much time.
Mill is a b&s
Thanks Ron in ohio
Janderso
Jeff Anderson
Mar 26, 2018
1,037
Likes
657
#23
kd4gij
Feb 7, 2011
4,672
Likes
1,846
#24
I have done that with a plywood blade backwards on a circular saw.
elewayne
Newbie
May 22, 2018
12
Likes
4
#25
Sorry, I'm not following that at all. Are you saying run the teeth up through the work. how would one hold it down, with the blade guide?
Hawkeye
Jun 17, 2011
1,849
Likes
571
#26
Still turns in the same direction, but the teeth are pointing up instead of down. Less chance of grabbing on thin stock.
Susan_in_SF
Wood and Metal Goddess
Jul 18, 2017
224
Likes
193
#27
I have a vintage Craftsman bandsaw that I plan to use to cut metal. I was planning on using a 1.5hp DC treadmill motor and my KB Electronics pwm chassis to have variable speed and torque at low speeds.
Eddyde
Bronze
Oct 13, 2014
1,421
Likes
1,208
#28
Sounds like a good plan.
elewayne
Newbie
May 22, 2018
12
Likes
4
#29
where would one ind a tread mill motor?
Hawkeye
Jun 17, 2011
1,849
Likes
571
#30
Check your local on-line classified ads for treadmills. Some are offered for free, others $50 or less. Get one with a rotary or slider potentiometer to control speed. The ones where you have to repeatedly tap a button to change speeds will drive you crazy. You can get a good stock of various materials when you take a treadmill apart. I've used the belt for things like way covers and car floor mats.
[6]
[5] [7]
