[4]
Metal/Drill bit question...
[3]
[10] Like what you see?
KBeitz
H-M Supporter - Gold Member
Apr 17, 2018
456
I have three shops at my home. weld shop... Machine shop... and a woodworking shop.
I like to have a full set of tools in each shop. I was making up a set of drill bits for my
wood shop and I was missing a needed 1" bit. So off to our local surplus supply store
I go... I found a 1" bit but the shank was 1" all the way. No step down. My drill press chuck
is only 1/2" . So I said no problem. I'll just turn it down. Right... It took me 1-1/2 hours
to turn down the shank to 1/2" Very very hard. The shavings look and feel like a Brillo
pad. Could this be a solid carbide drill bit? I've machined a lot of steel in my days but
nothing as hard as this.
T Bredehoft
Dec 27, 2014
2,834
You couln't have turned a carbide shaft. period. Its ground, only. Your bit is hard steel. nice job, BTW.
MrWhoopee
H-M Supporter - Silver Member
Jan 20, 2018
553
Definitely not carbide, but not a soft shank welded on either. You got one of the good ones, but it may have a tendency to slip, being that hard. You might consider putting 3 flats on it for better grip.
KBeitz
Apr 17, 2018
456
So... There is no way to turn carbide ? I have turned the shanks of many drills that I thought
was hard but this bit I needed to sharpen my cermets about 20 times to get this one job done.
It would only take a very small curl off no matter how hard I would push the cutter. I was using
a diamond stone to sharpen my cermets . A few time I could not get it to cut at all. I would resharpen
over and over until it would cut again. I tried different angles, speeds and feeds. Nothing seemed
to help. My carbide cutters would not touch it. If not carbide what might it be?
derf
Brass
Oct 3, 2015
721
I would not use a twist drill that big for wood, a Forstner bit would do a better job, without binding up and tearing out.
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
916
What do you mean when you say cermet?
If you can grind them it is an insert material that I have never used, from the picture it appears to be a common sintered carbide insert.
KBeitz
Apr 17, 2018
456
When I bought them i was told they was used cermet inserts.
A magnet will not stick to them. A diamond stone is the only thing
I found the will put an edge back on them. i have a few hundred
of them. Enough so I will never need to buy any other cutters.
It seem like only one side of one point on each insert was ever
used. I can flip the insert so I have 6 points to work with. I use
them until they break before I go to the next. I make my own
tool holders to fit the inserts.
Bob Korves
Jul 2, 2014
6,195
Your drill is probably high speed steel. It is quite difficult to machine other than grinding if it is at or near full hardness.
benmychree
John York
Jun 7, 2013
2,877
You were cutting HSS. The suggestion to grind 3 flats is a good one.
ELHEAD
Feb 13, 2014
264
Or re-grind to a brad point type drill. Think wood cutting auger bit.
Dave
Janderso
Jeff Anderson
Mar 26, 2018
1,144
A lesser quality bit would not have been that hard at the shank. I agree, you have a good one there.
I would not have spent the time. You have the patience of Job.
Nice work!
KBeitz
Apr 17, 2018
456
Thanks for all the reply's an help. The bit might not get used for wood but I
wanted a full set for in the wood shop... Thanks again...
dlane
Sep 27, 2014
3,045
Don’t get a set like these, but I bet they turn down easy. 7F6A34B9-5C19-44F2-A6FB-093B15EB633D.jpeg
mmcmdl
Staff member
Jan 31, 2016
1,142
Got some of those in at work ! :grin:
Janderso
Jeff Anderson
Mar 26, 2018
1,144
I bought a set of Rushmore 118 jobber size from McMaster last week. 1/8 to 1/2” in 64” increments.
They had TTC for about 30% less, I chose American made.
No more will I spend money on cheap drill bits.
[6]
[5] [7]
