Metric threads on pm1236
epanzella
Apr 8, 2013
1,557
You stop, back off the cutter, reverse the lathe back to the starting point, crank in your DOC, and go. There is a way to use the halfnuts but if you lose focus you'll trash your thread. When treading to a shoulder I stop the lathe before the finish line and use a chuck key to hand turn to the shoulder. You can also thread away from the chuck with the cutter up side down and the chuck in reverse but I don't bother.
Larry$
H-M Platinum Supporter
Dec 21, 2018
897
The upside down and cutting away from the chuck is well explained by one of Joe Pies videos. It makes perfect sense. Precision stopping not usually required. It also allows faster feeds once you get familiar with the process. He also advocates for cutting straight in. None of the fooling around using both cross slide and compound. It works fine for me. Now I'm going to catch hell from some folks on here. The threading chart on your lathe should show all the change gear locations. (Change gears are a PIA!)
Ken226
Jan 6, 2017
588
I've been using my half nut to cut metric threads since 2008. I've never screwed up a metric thread doing this.
Abom doest it pretty quick, but it's easy to learn if ya slow down.
You'll get the idea.
These days, I've set my lathe up so I can cut both imperial and metric threads with a joystick, never releasing the half nut.
woodchucker
H-M Supporter - Silver Member
Nov 25, 2015
3,181
Ok, I was successful using a combination of all of you suggestions.
you can release the half nuts, but you need to stop the lathe quickly after, then reverse the lathe, and re-engage the half nuts on the same number on the threading dial. if you are not using a threading dial, you can't do what I am saying.
by keeping the same number during reverse, you are just picking up where you left it.
FTlatheworks
Apr 24, 2021
213
Ya, I tried it with the thread dial like doing standard threads and it wouldn’t work. It wasn’t until someone told me to leave the half nut engaged for metric threads. It worked after I left it engaged.
It works engaging and disengaging on the same number for standard threads fine, but not on metric. I need to watch all the videos you guys have posted. I have seen bits and pieces of all of them, but I have a bad habit of skimming.
Ken226
Jan 6, 2017
588
The physics of engaging/disengaging on the same number works on metric threads, but there's one important aspect that must be understood. It can't be skimmed over.
In the sentence below, I'm putting in all caps the important aspects that CANT be skimmed over.
It MUST be re-engaged "IN REVERSE", on the EXACT same number.
To further explain. REVERSE, means the lathe is running in reverse.
EXACT same number on the thread dial, means, same member, + or - exactly ZERO additional rotations of the dial.
I'll make a video to explain. I'll post it up in about an hour.
Larry$
Dec 21, 2018
897
Practice @ your lathe's slowest speed. Use the KISS principle. HSS works fine, keep it sharp. Do you have a fishtail? Make a groove to your final depth next to the shoulder of the work (or @ the other end if threading toward the chuck.) Make a few air passes A DRO is nice but not required, touch off, then a scratch pass. It is easiest to see if you magic marker or Dychem it. Check with your thread gage. Was the setup for a right hand thread? What DOC? First pass can be .010+-Successive passes? .004"? or what feels right on your lathe. If you are cutting a metric thread on an imperial leadscrew lathe, you must always keep the half nuts engaged at the same location on the lead screw. You can disengage the halfnuts but don't let the indicator go around past your starting mark on the tread dial or you will loose track! (It is possible to find your start point on the leadscrew again but a PIA.) If you have disengaged halfnuts when you stopped, reverse the lathe and reengage the halfnuts as the mark passes. Rinse & repeat until the tool reaches the depth of the original groove. Chamfer the terminal end and lightly file the top of the threads to get rid of any fuzz and the extreme sharp if it is there. I suggest making yourself a numbered list of the steps (large print) and putting it where you can refer to it as you work.
About KISS.... Turning away from the shoulder is less stressful since it doesn't require a highspeed stop of the lathe and makes it possible to use the groove as the last-cut, set-point. Treat your lathe nicely, don't slam the halfnut lever in. As the mark comes up put a little pressure on the lever and you can feel when it will drop right in.
Note that cutting away from the chuck requires the tool to be used "upside down." Cutting straight in with just the cross slide eliminates having to turn two dials each pass and getting confused. If you go the two dial route, put a mag base indicator on the cross slide so you know you've returned to zero each time. Easier to see and confirm than the lathe dials. If you have a DRO it can also tell you the zero point & successive DOCs. If your lathe has a brake it allows higher speed threading ONCE YOU'VE MASTERED THE ART! Watch the pro's videos. Joe Pie has excellent ones including one on the use of thread wires that makes them a lot easier to use.
I was going to list all the things I've done wrong in learning to thread but there isn't enough room on this site!
FTlatheworks
Apr 24, 2021
213
I’m at work, so my last post about skimming made it sound like I don’t pay attention to any of your posts. I meant I skim through YouTube videos. I have done all of the things you guys have told me here. The cutting metric threads with imperial lead screw is the key there, but I couldn’t recall how to explain that. I do have the fishtail gauge as well.
Ken226
Jan 6, 2017
588
I went out and took a 9 minute video for you. At the end, I accidentally hit the power button on my phone and cut it short, but I think I got the most important stuff.
Sometimes I'm not as articulate as I think I am, so I hope this makes sense. It's uploading to YouTube now, so it'll be a minute before I get it posted.
The first part is just a recap of the old method of leaving the half nuts closed. I
forgot and used the joystick to do that, Its done the same using the apron lever though.
so just ignore that part.
I tried to put alot of emphasis on the threading dial, since I think that's the part you were likely doing wrong when you tried it.
AdBlock Detected
I've Disabled AdBlock
