U
umahunter
Forum Guest
Register Today
I'm not sure if this is the right spot but I figured I'd post up the quick belt tensioner I made for my jet jmd 18 mill drill since the original seemed useless. it's made from two pieces of angle iron and 1/2 inch threaded rod nothing fancy but it works. I welded a washer for the front but if you don't have a welder I'm sre a nut would work. You just turn the nut to desired tension and go hopefully this helps somebody
