- Jul 29, 2014
- 2,737
The Sheldon 0 is small enough and cute enough it can be on wheels, as is mine.
I wrote arbor when I meant draw bar so my reply was confusing....sorry.The overarm is forward, but the arbor is not the issue. It's the drawbar that enters the spindle from the back. If the drawbar is in place in the spindle when I set the mill, it's not possible to remove it because of the wall.
Wow Mike, you have a big one ... What machine is that? I know Gorton, but which?The ram on my Gorton mill sticks through the wall into the welding shop to save floor space in the machine shop area. Mike
This was going to be my suggestion.Many shops set their machines at an angle rather than parallel to the wall. You have to consider the bed travel and anticipated work but it would reduce the required distance for removal of the drawbar.
Don't we all.This was going to be my suggestion.
I’m trying to figure out an arraignment where I can put my Steinel SV4 on an angle and still have access to my end mill storage and such.
I really need a lot more room.
