Mill table tray
melsdad
Oct 17, 2013
363
I decided to make a tray to hold small tools on the mill while I am working on a job. It will also be a place to hang my vise handle and hammer. It is not finished so I will post updates as I go along. So far I have the tray finished. I milled a pocket so drills don't roll away on me. The inside of the pocket is cut with a ball mill, and the outside corners are rounded as well. I still have to cut the groove for the vise handle to hang on, and a few other details.....stay tuned.
Roughing the pocket. Loving the flood coolant for this process.
This is where I am for today.
sent from my hand held hickymajig
Very cool! It's always nice to be able to put misc stock in the shop to use. Aluminum should be good and strong for tray purposes.
So will it get bolted to the top via t-slots (near one end Im guessing?) Overhang the front edge a bit for hanging stuff?
Definitely keep the pics coming as you make progress.
A temporary solution I been using for the drawbar wrench and soft mallet storage consists of hanging it on the lock hex nut on top of the ram. Pic looks like it interferes with the quill handle but really doesn't. Does a decent job but a nice tray like you are making will be great for the vise handle and other miscellanea looking for homes.
The tray will be mounted to the front of the table by the t- slot. This way it won't interfere with the table surface.
Made some more progress over the weekend. The mounting plate is finished. The raised section will locate the tray in the front T-slot.
I have the slot machined for the vise handle, all the corners are radiused, and the hole for the air gun to hang is done.va5yzase.jpg
I am going to be hanging the drawback wrench and hammer from the tray as well. I am still thinking of how I want to hang those.
Your work looks good. I look forward to seeing the finished project.
Thanks for the comments guys! Should get back to work on it tomorrow.
Took longer than I hoped but got this project finished today.
