Guys I am three for three,what I mean I have use my mill three times and three times I have runt three end mills.Yes the end mills are cheap ones from All Indus. but I figure they would last little longer.What I am I doing wrong,I figure I would learn along the way but I don't have that many end mills.So looking at the spanner wrench that I made for my collet blocks I just wanted to mill the edge down which is only 3/8 thick so taking small passes and I runt that end mill so I called this project complete at the expense of one end mill.So moving on to my next project which is a shars axa tool holder that I wanted to make little wider till I order couple XL's.So started with new end mill which I believe is 1/2 so I set the rpm to 920 if I figure it right.Not knowing how much of a cut I just made several passes removing .010 with each pass,and I see the slitter of metal coming off with each pass.Guys I am hand feeding this no power feed yet but I was taking it easy so maybe to easy?Well after several good passes the slitters of metal were not coming off anymore so I took a measurement.Made a pass and remove nothing.I know its hard to answer this question but .010 per pass at full depth of the tool holder which is maybe 5/8 does not seem like a lot nor was the mill sounding like it was straining any.Should I have feed faster or take deeper cuts which each pass was conventional them moving back was climb pass.I just don't see what doing wrong but what ever it is I need to stop.But stop what?
