Probably an odd guestion, but I need to ask because I have never personally seen a "proper" coolant system set up on a milling machine. My mill has 2 pipe plugs screwed into the rear of the table at each end, obviously for draining coolant/lubricant from the table when employing flood coolant on a mill. I'm just a hobbyist doing one offs so I don't require flood coolant, but I have been hogging a lot of material lately and even using my little spray bottle is filling up the table with solvent.
I'm just wondering what they use in production shops to hook up these drains to the sump in the machine base? It has to be some type of flexible hose that is water/oil/coolant resistant. The question is what material works for this?
