While learning to use my mini-mill, I came up with a question: is there any valid reason the most common hold-down straight slotted clamps are designed in such a way that you can almost never have two attachment points per clamp (that is, have two threaded pins at the opposite ends of the slot, with the part you are machining "positively" secured between them)? The slots and/or the clamps are usually not long enough... Say, you are working on a narrow square-section bar stock, like 1" wide. Why not have two dual-pin straps securing it at both of its ends? Wouldn't this be a much more reliable setup than having one threaded pin per clamp? Yes, I do know you can still hold it down with the regular clamps, with the 1 pin/clamp situation. I just don't see the point of preventing one from doing it as described above (though I'm sure I must be missing something)...
