- Mar 19, 2011
- 940
I have to make some 1/4 wide x 3/4 long slots, all the way through the end of 3/4 x 3/4 CR steel. I have a Rockwell vertical mill.
Should I do this with a 1/4 inch, 4-flute mill, and cut them from the top, or should I get a 1/4" side milling cutter and work horizontally? I already have the arbor.
If the recommendation of the group is to go with the side mill, what diameter would be best, and what speed would you suggest?
Thanks from a newbie!
(As a side question: when I make a cut, must I raise the cutter clear of the work before returning to my start point, and then recalculate my depth of cut and move in, again? Or can I just back out, go deeper, and cut? Does backing up damage or dull the cutter?)
