- Apr 23, 2018
- 6,613
See which US model has the same chassis, and just order a Curt or Draw-Tite bolt-on frame mount hitch for it. They're really not expensive, and Amazon ships big for free. I put them on everything, even cars, because they're great for mounting bike racks. A bumper mount hitch is for very light loads and is only meant to project an air of both sport and utility to others who see you on the road. Your vehicle is not a 1-ton, but so what, the Millrite is 1300 lbs. That won't be too much tongue weight for your Toy, and is even below the 3,000 lb trailer limit, so you could legally drive it without trailer brakes. That makes it cheaper, brakes are a good idea, but I'd be more concerned about having enough air in the tires in terms of magnitude. If you work out your loading and unloading situation, there are a lot of trailers out there that will fit your vehicle's capacity as well as the weight of the mill. The drop trailer requires a commercial vehicle because it can carry a much larger load than you are planning. Your truck will haul that mill just fine. How many people do you see hauling four motorcycles or a pair of jet skis with a full Toyota SUV? Those loads weigh as much as your mill.
