[4]
Milwaukee Model H Mill
[3]
[10] Like what you see?
Jason Annen
H-M Supporter - Gold Member
Jun 6, 2015
255
Found one locally, has arbor support, and that's about it. He won't give me a price, says offer what I feel comfortable with. He is not sure of the spindle taper.
It looks solid, but I am not sure of the value, thinking about offering a $1000.
Thoughts?
Jason
timvercoe
Active Member
Jul 4, 2014
127
A little more info vertical? horizontal? And Model? Actually arbor support is a clue............horizontal! KT's are big heavy machines, and not easy to move so this usually affects the price. Horizontal arbors and cutters are really expensive new................. and around used but expensive to ship. If you want to use it to do vertical operations you will need some fairly large angle plates, you can make these if you have time and materials. Bottom line is get as much as you can that fits the machine. One of his alternatives to dispose of the machine is to scrap it. In my part of the world scrap is 50 a ton at the scale. A moderate KT horizontal is 6 tons. So basically that's the bottom line. Most of us that have them would rather give them to some one than scrap it. Again heavy,, how are you going to move it? Pay a rigger? It will be interesting to see how this goes.. Probably MTB50 taper, unless it is really old then it will be probably BS9. And a really old machine will be smaller and lighter.. my thoughts Tim
timvercoe
Active Member
Jul 4, 2014
127
Now I see that it is a model H, personally have no experience with that model, but they are smaller thus lighter check the PM website lots of info there. Guys that have 'em love 'em. Tim
Jason Annen
Jun 6, 2015
255
Going to check it out tomorrow. It's still under power, so I can run it. I don't think he knows too much about it, plus he has a ton of other things. Going to take it all in and hopefully there are so good accessories for this machine hiding in the corner.
Jason
Jason Annen
Jun 6, 2015
255
He thinks it weighs around 3000, if it's anything other than 40 or 50 taper, I will pass.
Jason
timvercoe
Active Member
Jul 4, 2014
127
good luck with inspection! look forwar to hearing/seeing results
Jason Annen
Jun 6, 2015
255
Got it off the trailer tonight. The x axis power feed lever is loose, and the y axis wheel comes off, which I don't think it should. There is some slight surface rust on the table, but no visible milling marks in the table. All the ways look really good. Needs a real good cleaning and the coolant tank looks really nasty. Overall, I am very happy with it. Paid $1200 for it with some tooling. Its 50 taper.
I got 2 overram supports, one with a .715 bore, and the 2nd one is pictured.
Not sure of the weight, but my 2 ton electric hoist did pick it up, I am thinking it's close to 4000 lbs.
Jason
IMG_20160907_200108576.jpg IMG_20160907_200155438.jpg IMG_20160907_200138273.jpg IMG_20160907_201258835.jpg IMG_20160907_210433175.jpg IMG_20160907_205901087.jpg
mce5802
Oct 28, 2014
124
Check out Keith Fenner's "Broken knee on the K&T" on YouTube. His is a 2H and it seems like his y-axis handle slides right off too.
brino
Jan 2, 2014
3,541
Great looking machine! Congratulations.
It's hard to get an idea of size....what is the overall height?, what's the dia. of those overarms? table size?
I have watched some of your previous overhauls. Please post whatever you can!
Thanks.
-brino
Jason Annen
Jun 6, 2015
255
It's 5' from the floor to the top of the machine. The table is 10"x50". The knee is 26" deep, and the over rams are 3.5". 5hp, power feed and rapid on all axis. 35 to 1400 rpm. 1/2 to 20 ipm on the feed.
I was told it should handle a 6" face mill, 1/4" doc with no problem. I might paint it next year, we shall see. I am well into the VN 16s now.
Jason
Old Iron
Sep 29, 2010
1,558
Good mills ! Both my mills are K & T. I cut some T nuts on my horizontal cutting both sides at 5/8 deep one pass it never slowed down. Great machines. I also paid $1200.00 for mine and hall it from New Orleans to here in Alabama. Easy move.
Paul
FOMOGO
Sep 2, 2013
1,918
Really nice machine. It's good to be able to take big cuts when it's called for. Mike
Silverbullet
Gold
May 4, 2015
3,448
Great mill to own. Ever notice most all the war year machines work and keep on working. Our might came out because of the times. The strength of the nation is still evident by value of making things to last not the need to be replaced frequently. Nice machine I bet she don't need much to bring her up to being a favorite to use. Never had one but ran many , there made to work and do it well., glad you saved the old girl , keep us posted.
ewkearns
Active Member
Jan 6, 2017
86
I own a war model 2H more or less identical to this one.... post the serial number and I'll tell you the year of manufacture. The "Y" axis wheel should not come off. You don't want to know what I paid for mine....
commoncal
Newbie
Nov 30, 2017
6
I am new here so here goes nothing. I bought a sweet K&T 2H with a plane vertical head on the parking attachment last week. Its still in a basement in Prescott along with a lot more iron I will be moving over the next two weeks.
This pile belonged to an old pal of mine who pasted on a while back. There is still a Hardings lathe and a grinder to dispose of.
The K&T 2H is the heaviest lump in this pile and if any of you have any real Idea of the weight of this thing please post it.
[6]
[5] [7]
