[4]
Mini lathe taper bearings problem
[3]
[10] Like what you see?
Sdmf5150
Active Member
Mar 13, 2017
44
I am trying to install the taper bearings on my HF headstock, but when I get the spindle installed I have about 3/16 space between the plastic spacers that go on either side of the gear, letting it slide around on the spindle. Definitely not going to work like that. Anyone else have this issue?
royesses
H-M Platinum Supporter ($50)
Aug 23, 2014
685
Did you make sure that at least one of the new bearings (rear one) has a sliding fit on the spindle? We have seen that before. That's about all I can think of for the loose fit of the hi/lo gear. Maybe bearing outer race not all the way pressed in?
Roy
MasaAMD
Active Member
Jan 1, 2017
31
I'm having this exact issue. I have the Grizzly 7x12 and with the outer races fully seated and using the original spacers I have about 3/16" axial movement of the main gear on the spindle. I'm going to order some additional spacers to account for the inset of the inner race on either side. I will let you know what sizes work for me.
royesses
Aug 23, 2014
685
Please let us know what you find wrong. I installed tapered roller bearings in my 7x10 quite a while ago and did not have a problem. I used all the original spacers and cut down the rear spacer to get the drive gears aligned about .090". I also notched the rear spacer to make installation of the key easier. There are 3 spacers in mine one on each end of the main gear(they are the same thickness) and the long one that is between the adjusting nut and the rear inner bearing race.
Roy
Richard King 2
Master Machine Tool Rebuilder & Instructor
H-M Supporter - Commercial Member
Feb 1, 2018
525
Please explain why you took it apart or does it come apart and you have to assemble it? Did you take a cell phone picture before you took it apart? Have a manual that has a drawing ?
MasaAMD
Active Member
Jan 1, 2017
31
This upgrade involves replacing the OEM headstock ball bearings with with opposed tapered roller bearings. Due to the construction of the bearings, the outer race sits proud of the inner race by a small amount. This extra space now allows the main gears to have noticeable axial play on the spindle. To remedy this slightly thicker spacers need to be machined. Also due to the offset of the inner and outer races the rear spacer needs ~0.1" taken off.
I just got my spindle back apart and I'll take some measurement to see how thick I need to make the new spacers. Also, I'll post some pictures to illustrate what is going on.
Edit:
Just found a great picture showing the differences in the bearings. (source: http://www.toolsandmods.com/lathe/mini-lathe-headstock)
Assuming the Nachi bearings are dimensionally the same as the SKF, this shows a 3.25mm offset
MasaAMD
Active Member
Jan 1, 2017
31
Here are some pictures:
Looking at about 0.055" offset from the outer race to the inner race.
Original spacer:
Two new spacers @ 0.346" need to be machined. This should take up the extra axial play.
royesses
Aug 23, 2014
685
Thanx for that information MasaAMD. I never even bothered with the extra end play on the spindle gear. I have all metal gears in mine and have had no problems with noise or anything else. I remove the spindle every six months to repack the bearings and the next time I'll make some spacers.
Roy
[6]
[5] [7]
