Not my experience,,,,, I’ve tried it and my machines stared to rust. Went back to oil, either in coolant pump or applied by brush and no rust.Water soluble DOES NOT promote rust.......
You mixed it wrong.Not my experience,,,,, I’ve tried it and my machines stared to rust. Went back to oil, either in coolant pump or applied by brush and no rust.
You do not know that for a fact. It is possible, however. I have used water soluble oils in the past, but I always made sure to dry off the machines and spray them down with a penetrating oil like WD-40. That is why I was thinking, "Why not simply use WD-40 as the coolant spray?" The only reasonable answer of which I can think is, "Cost". As per some of the responses here, it would seem the water-soluble oil can be less expensive.You mixed it wrong.
Every CNC machine I have ever seen uses it, our shop uses it on all machine.
and some might say it smell's better. (although I would be lying if I didn't admit that I kinda like the smell of WD-40, is that wrong?)it would seem the water-soluble oil can be less expensive
