- Feb 2, 2017
- 1,234
Those leveling casters look similar to the Carrymaster. The downside of that approach is that the diameter of the wheel is relatively small, so rolling will be more difficult if the floor's not completely flat and clean. Of course the downside of the Albion caster approach is that I'll either need to raise the machine ~6" (increasing "tippy-ness"), or build a frame with outriggers.I recently made a stand for a cnc machine. it only weighs about 450lbs but I used 3" square 1/8" wall tubing which added another 250lbs to the weight. Anyway I used leveling castors on the legs like these :
https://www.amazon.com/s/ref=nb_sb_ss_c_2_10?url=search-alias=aps&field-keywords=footmaster+leveling+caster&sprefix=footmaster,tools,259&crid=1YXJ6FMSI5H0B
I believe they make them to support up to 3300lbs per wheel. They aren't cheap, but work very well and allow you to move the machine easily and then lock down the leg and level easily. A great option if you want to make your own steel stand.
Thanks for everyone's input. I need to re-look at my shop layout and see if I can find a logical place to install the lathe semi-permanently. I've got a wall and a closet that I can remove that will significantly increase the open area, and that may be enough so I can find a place along a wall for the lathe and mill.
