[4]
Morse taper #3 to #4 adapter
[3]
[10] Like what you see?
nnam
Active Member
Jul 15, 2016
90
I saw some going from #4 to smaller size #3. I have #3 and I want to be able to use #4 drill bits since I happen to have a bunch of them.
I know some people may say that may "overload" the lathe. However, I think as long as I don't force it or step drilling things, it should not cause an issue.
I post here for more responses for pros or cons to this from the experienced machinists.
Furthermore, and more importantly, I can't even find such a thing.
Some of my concern is that if I can find an adapter, it'll be sticking out a bit, shortening the length of work area, but that's not so much of my concern, at least currently.
Another option is is to sell the bits, and buy new bits that works. It just means I probably lose a lot of money on shipping and the hassle of selling them. I don't know if there is a good solution to this.
nnam
Active Member
Jul 15, 2016
90
ok, I just suddenly found one solution that works. I am still open for more, since experienced machinists probably know better:
CXA tool post holder for MT4.
Chipper5783
Sep 25, 2014
771
What sort of a machine do you have? I'm guessing that with a #3 in the TS, it about 12" - 16" machine.
I am a big fan of drilling from the tool post (so the CXA to #4 is a good choice. I did not know the CXA was available with a #4 - that is awsome.
You can get a #3 male to #4 female, with a torque arm. I have never used one (the drilling from the toolpost is just so slick, I can't really see an advantage to using the tailstock). Using the adapter, without the torque arm I think would be a bad idea (though on the little anti-rotation key, also you would not want the tool to slip in the taper - if you don't have the tang socket in the tailstock and not all lathes do have the tang slot).
pstemari
May 18, 2015
437
The MT3 male to MT4 female adapters are certainly available, but they do require a lot of stick out. Here's a US-made one, but you can get a Chinesium one for about half the price:
https://www.mscdirect.com/product/details/03732070
Presence of a tang shouldn't be a major consideration. Properly installed tooling shouldn't put any force on the tang. Other than ejecting tooling, the tang is, more or less, a historical artifact. It can't generate enough force to make up for the taper slipping.
Sent from my Pixel XL using Tapatalk
Chipper5783
Sep 25, 2014
771
Another options (factory available with DS&G, Mazak, probably others makes with heavy pattern offerings) is a dedicated plinth that bolts directly to the cross slide. How big are the drills? Strictly speaking, you won't overload the spindle, if you go easy, the cross slide should be fine too.
As I said above, I am a fan of using a CXA holder on the toolpost (I have a CXA on my 15" lathe, but only a CXA-#3MT holder). I have not fitted an anti-rotation arrangement, so it is possible for the post to slip (which has happened to me, but if you are paying attention (which you better be) then it is not a big deal.
My largest drill is 1-1/4" , which I have in both #3MT and #4 MT. I very rarely use such a large drill. Any hole of size - I'm going to bore it anyway.
nnam
Active Member
Jul 15, 2016
90
my lathe is a Leblond regal 15".
Yes, boring the hole is a good option. I am not quite sure what you meant about "slip" Do you mean the CXA tool post just loosen up on the holder? The holder is at a vertical angle though, so maybe you meant the tool post just rotate on the compound slide?
It's my lucky day today though. I just found out that my 20" drill press uses MT4 for the chuck. I removed the chuck with a wedge and I was able to put the drill bit in with no problem. This is great bonus. Not everything I drill has to be on the lathe. Odd shapes, large shape, etc.
I don't drill larger size than 1" alot, but I think there were cases before that I needed it.
nnam
Active Member
Jul 15, 2016
90
Wow, nice. I searched alot, couldn't find it, but you have it so quick. As I found out more above, looks like I may opt for the CXA option if I need it, but this is a very good choice. Now that I can use the drill press, and just use bore for large hole in the lathe, my needs for this adapter is much less.
Chipper5783
Sep 25, 2014
771
By "slip" I mean that the post rotates slightly on the compound. I have made ~2" diameter washer 0.05" with a good portion of the center relieved, so that the center post bolt loading is further out. I don't recall if I have had it slip since I added the washer.
Once the middle has been opened up enough for a good sized boring bar (i.e. 1") - it does not take long to clear some space.
It sounds like you must have landed a great bargain deal on some large drill bits. Now you are figuring out how you can set them up to use them? That you would rarely use them and have other good options for opening up the center of a piece of bar - that is totally beside the point.
Drilling is generally a roughing operation, so depending on the project - you might be able to open up the first hole on that 20" drill press and then transfer the job to the lathe? i.e. perhaps you don't needs to spend much time sorting out a solution that you almost never would actually need to use?
Very cool to have a "bunch" of big drill bits. I scammed a 1-7/8 (thrashed MT5 taper) - for free. Again, I totally don't need it, but it is cool!
Please post a picture of your collection.
nnam
Active Member
Jul 15, 2016
90
I always wanted larger drill bits due to some prior need for them. Having a set of used bits for good price is very nice and if I can use it in one or two times, it would be worth it. I think they're made in the US, so I think they have good quality, although they look very well used. I looked closely and most of them can be good bits, especially if I can sharpen some of them. The cutting sides are very good. The tips are mostly good. But the sides are what I concern because I can only sharpen the tips.
Here is a picture of them. I got them part of something else, so I don't know their exact cost for me, but I think overall, I got decently good price for a well used set.
bfd
Staff member
H-M Platinum Supporter ($50)
Sep 9, 2016
434
one option would be to turn the #4 mt down to a #3mt with some filing with bluing you can get a good fit to your tailstock, but you could still have an overload condition on your tailstock. where I once worked you could check out many size drill bits with different size tapers. you will have to rework the tang also. some of the larger size drill bits have a center in the tang to help you set up the drill in a lathe. bill
Chipper5783
Sep 25, 2014
771
Noam, you are correct, you can only sharpen the tip of a twist drill. If the lands are worn, then just grinding the cutting edges does not help - the cut hole will be too small for the drill. When using a drill with worn lands, you make lots of heat, it makes a mess.
Of the lands are worn, it is most likely just near the tip ( from the PO tring to get away with just a tip grind). There is an easy solution, just cut the drill bit back about a 1/2" and repoint it. I use an abrasive disk to cut the bit, making a sort of point to reduce the amount of grinding. I find large bits are easier to grind than smaller ones - you can see what you are doing.
GoceKU
Brass
Jul 14, 2017
925
I've come across the sleeves to use lager drills in small morse taper, i've got couple myself but very rarely use them as my lathe has MT5 on the tail stok and MT6 in the spindle. Also from past experience, you can't break lot of stuff with using them, worst case you'll break the end tab off the sleeve and have to use a magnet to fish it out.
pstemari
May 18, 2015
437
Wow in that link you provided, this one is at much lower price:
https://www.mscdirect.com/product/details/00186437
As I said, you can get a Chinesium one for about half-price. Interstate is MSC's import brand. Some of it is relabelled MHC items, which I've had decent luck with. Other stuff is totally anonymous, which I suppose is their right under the 5th Amendment.
BaronJ
Brass
Aug 7, 2018
660
Hi Nnam,
I wouldn't even consider using a Morse taper adapter like that ! I've turned the Morse tapers off to make drills into "Blacksmith" style with 1/2" shanks before now.
Chipper5783
Sep 25, 2014
771
Seems like Nnam has his solution, with the CXA-MT4 holder ($36 from Shars). That is about the same price as the #3mMT - #4fMT and I agree I would not run something like that in the tailstock. Baron's solution is fine, but I'd go with a CXA-Type 4 or Type 41. They are pinch style BB holders for 1" or 1-1/4" rounds respectively. But to go with the turned down shank, then the won't work in the previously mentioned 20" drill press, having a MT4 taper. Granted the Type 4/41 would have other uses.
Nnam, what is your final decision?
BaronJ
Brass
Aug 7, 2018
660
Hi Guys,
Yes I agree with chipper ! The CXA holder would be the way to go if you didn't want to turn off the taper.
I was looking at my drills this morning and trying to locate my biggest drill ! It seems that 1" is the biggest. The taper has been turned off. Woe is me, it is too long to fit in my drill press without taking the X-Y table off. Even then I might not be able to get my workpiece and vise under it.
nnam
Active Member
Jul 15, 2016
90
I am going to go with the CXA holder route. Do you have a link for that $36? Hopefully the shipping is not too much. I can only find more expensive items.
The one link that has lower price is this, but I am worry this site is a scam web site:
http://www.cbsvosale.top/index.php?main_page=product_info&products_id=3336
I am think with the CXA, I can later use the MT4 chuck on it to hold relatively large round shank bits (that are not MT4).
BaronJ
Brass
Aug 7, 2018
660
Hi Nnam,
I'm inclined to agree with you, I've not been able to find any reference as to who owns the company or where abouts they hide.
There is little or no information about .top and trying to search it gets blocked. The web site blurb says they are a clothing company !!!!
Chipper5783
Sep 25, 2014
771
It is a #53, on page 119 of the Shars catalog. http://www.shars.com/products/toolholding-workholding/quick-change-tool-post-holders/morse-taper-holder-5-and-53-type-353-cxa
Most of the round shank bits are set up with a 1/2" shank. With a larger bit, that is difficult to hold (grind 3 flats on it) - a bigger chuck will be stronger, but it generally hangs out further too (just being bigger does not necessarily make it a better setup). If you have a dedicated boring bar holder (such as a type 4 or 41) then size it for that - strong and compact. If you only have square holders, then make yourself a square holder/split bushing for your largest tool holder - I think you can get CXAs up to 1-1/4" opening - and bore it for a decent size round shank. Drill shanks are not hardened - you can trim it to whatever size works for your equipment.
nnam
Active Member
Jul 15, 2016
90
Thanks for the tips. Somehow I thought #54 is the only good option. There are more #53 and also better price.
nnam
Active Member
Jul 15, 2016
90
I ended up bought a set of cxa tool holder, knurling, mt4, 250-302xl kit (all 1" size)
I had to make a base and bolt for the tool holder because the provided one is too big to fit the lathe.
Going to cxa-xl is just amazing. I lucked out with my previous used lot purchase including mt4 drills above, which happened to have many carbide 1" bit holders. They are super rigid. I didn't pay attention to them, since I didn't have a tool holder that big. Wow, I love them.
I recently bought 3 more cxa 250-302 xl from Walmart (cheapest price I found for the same items). Added with $25 off for signing up a credit card (have to spend > 25%), it was a good deal. Free shipping, beat all others total price.
Here is a link in case someone wants it:
hman
Feb 17, 2013
2,240
WALMART????!!!!!!???? I'd NEVER expected to see actual tooling offered by Walmart. But there it is! Just for fun, I searched on "BXA tool post". Lo and behold! Looks like they're acting as "middle men" for All Industrial. Who'da ever thunk?
darkzero
Global Moderator
Staff member
Nov 27, 2012
3,704
So many retailers do this now, Sears/Kmart, Staples, Target, Home Depot, Lowes, CVS & many more! I find it so annoying when searching a retailers website for something, easy enough to filter out the 3rd party items but still.
cathead
CATWERKS LTD
Feb 7, 2013
1,072
I have some #3 Morse taper bits that were turned to a cylinder in the bottom inch or so. Apparently they
wanted to put them in a Jacobs type chuck or something. They still work as Morse taper too. I did add
a tang to one of them because of the reduced area of the MT taper. It's not something I would do or
recommend. Anyway, they are still usable bits.
[5] [7]
