- Sep 10, 2022
- 928
I have an old Wards Lathe. It is running an old Craftsman 110v motor. It died on me. It was only wired for forward. I just came into possession of a dual voltage reversing motor. The lathe came with a Furnas brim switch style RSB4. I am pretty much electrical illiterate. However if I have a simple schematic I can wire it.
So here are some questions and pictures of the actual motor and switch.
1. Will this switch work with this motor? If yes the following.
2. From looking it appears that the motor is setup for high voltage. I will need for low 110v direction on what wires to switch and where.
3. What is the wire sequence for drum switch and where do wires come from on motor to drum switch.
I have this from my SB9
It looks like Figure 6 for this motor?
Cutting oil is my blood.
