- Apr 4, 2016
- 853
Tom,I'll look into bearings, but I need it soon, may have to run it with wobbly bearings.
If the problem is a bad bearing (very likely) it's a pretty simple job to replace the bearings. But, if you continue to run it as-is, you run the risk of a bearing spinning on the rotor shaft or spinning in one of the end bells. If that happens with a small motor like you have, it will likely not be economical to repair at that point. So, I would suggest you fix it as soon as possible.
Ted
