- May 16, 2016
- 210
I am currently (ha!) nearing the end of my shaper refurbishment, and was planning to use an older GE 1/3hp motor I saved that had been used to power a jointer. Ran good, was reversable to get the proper rotation direction for my needs, but it was pretty full of oily sawdust. Pulled it apart to get as much out as possible, but when I put it back together it has a feeling of drag when I rotate the shaft by hand. I am guessing, and am pretty open to being wrong about this, that the bells are slightly out of alignment. I know I have it reassembled correctly, as both oil cups are pointing in the same direction. I have backed off on the four through bolts to eliminate that as a cause, but I was wondering if there was some trick to getting these back together? I have rebuilt motors in the past, but never had an issue with the alignment before.
Here is a pic of the motor, to show what I am working with:
2022-11-22_06-33-22 by Aaron Warfield, on Flickr
Thanks in advance!
Thanks in advance!
