- Sep 20, 2021
- 152
I'm starting a new project building a belt grinder. I want to re-use an existing 230V motor that I have laying around. I took some measurements of the shaft:
OD = .850 (just under 7/8'')
Keyway = .250''
My options for the drive wheel of the grinder are either 7/8'' bore or 5/8'' bore, both with 3/16'' key slots - I'm trying to figure out what's more economical and easier to accomplish (with my skill set). I have these choices as I see it:
1) Buy a drive wheel with 7/8'' bore and make a shim for the undersized shaft, then cut a 1/4'' slot through it; re-cut the keyway
CON: may be difficult for me to make such a precision bushing: (.875-.850) / 2) = .0125'' wall thickness);
will need to broach the key slot to 1/4''
2) Buy a wheel with 5/8'' bore and turn it to the dimension I need (.850'') for the correct fit
CON: will need a broach to make a 1/4'' key way slot
3) buy a new motor...
Maybe there are other options that I'm not seeing, could use some help.
Keyway = .250''
