- Dec 16, 2014
- 85
Hello,
So, I've been pondering using my mini Air Die grinder in my AXA boring holder as a mini tool post grinder (South Bend 9A). I've seen some use this with success. But, am a little concerned with grinding dust. Even if I use a vitrified type stone while adding way protection, I am a little clueless on the optimal shapes to use for various purposes. I am guessing a selection of grits and shapes would be worth having. Here I am just looking for some of the most common shapes and sizes that would fit this application.
So, I thought it would be a good discussion topic. One other thought that came to mind was to see if there were any CBN type mounted points, or if anyone has used them to any level of success. The idea would be less grit to deal with.
What about Cratex, or buffing wheels? Other cool things I haven't even thought of yet?
So, with a 1/8" Shank in mind, what comes to mind for what uses?
Me, I am just trying to expand the usefulness of my lathe, and potentially add some nicer finishes and ground angles, points, or flats to my projects. Thats what I had in mind anyway.
Thoughts?
Thoughts?
