- Sep 24, 2014
- 929
Hey Don, I typically glue and screw the sheets together. It takes a lot of glue to get good coverage. You want to spread the glue evenly on both pieces then slide them around to make sure you get good adhesion. I would also seal all six sides of the wood with paint or poly. I just did a top last week for a CNC router I am building and painted it with Rustoleum Hammered paint. It came out great and looks like it is a thick metal plate. I also band the panel with some hard wood as plywood tends to chip on the edges. I have all of my smaller bench top tools mounted on tops like this. Baltic Birch plywood is the best choice as it has no voids, but it is much more expensive. I typically just use standard birch/oak or MDF for my tops.
