- Feb 25, 2021
- 3,130
I've gotten a few requests for pictures of moving machines, so here you go - pictures are thumbnails so you should be able to click them open for a full size picture.
I needed to move this mill four feet and turn it 90 degrees. Mill: 9000lb Kearney and Trecker 3K vertical. Tools at hand: 7000lb tractor with loader and forks, toe jack, three skates, and one helpful spouse taking time out from barn chores. Challenge is that this shop is too small to turn the tractor into position other than straight in through the door. The loader will lift about 3000 lbs, so no where near enough to actually lift the mill. So this was a matter of sliding the forks under and moving it forward a few inches to a foot, then pulling back on one corner to rotate, with frequent lifting with the toe jack and repositioning the skates. Repeated about 8-10 times. The strap I used is undersized for a reason, the tractor has an electronic clutch, no feel, so the strap stretches a bit to take the jerk out of the tractor clutch action. Total time was about 2 hours.
