- Dec 2, 2012
- 1,729
I did a search for cast iron spindles with steel back plates, other than the dampening properties, I really couldn’t find any negative. (Doesn’t mean there aren’t, hence my posting here before I jump in) Yes, it has a register that I made sure was snug, tight tolerances. I moved the chuck/back plate closer to the headstock as the videos show. I definitely see positive outcomes from the less flex of the setup. I can get cast iron blanks if it comes down to that, but like many people, I hate machining cast iron.
Sorry I had not seen the vids.
Have you checked that the wobble is bending and not just the pre-load on the bearings ?
Maybe run it for a while and see if it's the same or less once the bearings are warm.
Stu
