- Nov 21, 2010
- 1,602
His newest release being a powered leed screw on his Atlas. Over many years in my aquired stock
(of junk) I do have the controler, fwd/rev gear motor, tons of pulleys and belts, and I have always
wanted to do this only to a SB. Problem is, there is no room for a lead screw pulley. My guess is the
Atlas screw sticks out of the support bearing further. I do not want to move the support bearing, or
weld, or drill and tap the lead screw. Any ideas without using glues. To bad there is not enough
clearance left of the bearing or Id cut a pulley in half and clamp it. Also I really dont want to drive it
off the lead screw gear either. So anyone that has an Atlas, just tell me the screw sticks past the
bearing for a pulley, then this idea will go to rest. sam
