Mt 3 vs backing plate ?
jpackard56
H-M Lifetime Diamond Member
May 22, 2019
185
So, I sold my Craftsman 109 and in continued cleaning found a working Craftsman 4 jaw chuck with the 1/2 x20 threaded solid back. Would I be better off selling it too and getting one with a backing plate for my newer mini or would a Mt 3 screwed into the 1/2 x 20 be strong/rigid enough?
Cant you just get a new backing plate to fit your new lathe? I guess depending on how the new one is setup you might even be able to drill and tap a few extra holes into the existing backplate so it fits the current mini!
A 1/2 -20 thread is not sufficient for mounting a four jaw chuck, IMO. It is niether rigid nor strong enough. Also, if you use a Morse taper, you will need a drawbar which precludes any through spindle work.
My thinking (which could well be wrong) was that some guys seem to be looking for these in their original configuration and maybe I would be further ahead to just sell this original 3 inch without mussing it for a collector type person and put the $$ toward a 4inch....
The Mt3 arbor was so that I could use it right away without a whole lot of fiddling. I clearly had not thought about the draw bar issues ( I would have to make one up and yes it would preclude depth access....
See why all the experience available here is so beneficial to a newb like me !
Thanks fellas, I'm gonna noodle on this a while more and probably open the one I have up this weekend to see about making a different back or possibly getting access for mounting with what is there, although what is showing seems pretty thin...
FYI - that little chuck looks like it's in really nice shape! Lots of times the 4-jaw doesn't get used as much as the 3-jaw because people find them intimidating or too much fuss. Consequently, they can stay somewhat mint if they just sat on the dark corner of the shelf. Might be a nice little chuck to keep around for smaller work.
-frank
I think that may be the way to go.
