- Sep 8, 2019
- 4,392
If you suspect that your headstock and tailstock are out of alignment, then a tapered item sounds like a great first project!
I found that the margin for error for a tapered dead center going into a spindle nose is more than you would think. The first dead center that I made, I thought I had completely hosed the angle (I did overshoot it a little, resulting in too shallow of an angle), and it fit wonderfully. By the time I made the fourth one, I had the angle down pat, and the resulting fit is too tight for my taste. A proper Morse taper male and female pressed together is not always so easy to get apart.
