[4]
Muriatic acid mistake!
[3]
[10] Like what you see?
mariner3302
Active Member
Feb 27, 2015
47
First off, if you are thinking of using muriatic acid on cast iron, STOP. Yep, STOP and don't do it. I read online and saw a video that demonstrated it as effective and a safe method of cleaning and derusting. And to that end it does work. EXCEPT (and after it was on already), I found gobs of sites and threads saying don't use it on cast iron. One said that he left it in a soak tank for a day or so and it actually softened the cast iron so much he could remove some with a fingernail. I used it to take some flash rust off the legs on my 1937 South Bend 11" lathe. Only after applying it with a spray bottle did I read that it gets in the grain and continues eating cast iron for years if not completely neutralized and/or removed. So I scrubbed the legs with Soda Ash because it was handy and a green scratchpad. The legs are all white now from the soda ash (about 50/50) rinse and scrub. The worst is I am now worried about painting the legs.
So the question is, will soda blasting neutralize muriatic acid on cast iron or would media blasting with black diamond be enough? The legs are almost all back to metal except a couple spots where the black original fillers were applied.
mariner3302
Active Member
Feb 27, 2015
47
Yeah, read about a guy who had some in his shop and rusted everything exposed to air! I threw that stuff out and it makes me think it could have been responsible for some things rusting lightly in the shop.
markba633csi
Gold
Apr 30, 2015
3,842
It used to be sold in very thin poly bottles and strong (36.5%) and I had some in my garage. One of the bottles had a tiny crack in the plastic and over time I started seeing rust on my tools- Fortunately I caught it in time- I store it outside now- one of my mikes seized totally and got ruined
M
Ironically it's very good at removing rust when in liquid form
Cadillac
Brass
Mar 12, 2018
884
One thing to also remember that I found out the wrong way is. Is Cleaning outside calipers or layout pointers with a spring steel hoop on top. DONT CLEAN SPRING STEEL WITH VINEGAR! I recently got some dividers from a garage sale really nice made in Germany. Had minor rust figured a little soak in vinegar which I’ve done a lot with great results. Just never spring steel. Well ten mins. Soaking I went to brush and found the divider in pieces. Hoop was broke in pieces and arms were just laying there. S.O.B! At least it was only two dollars but a lesson well learned! I would never use muratic acid for steel just for the fact that it rust just as bad afterward as before cleaning and it stinks. Only use that for etching concrete.
Tozguy
Feb 15, 2013
1,915
To the original question on neutralizing acid soaked cast iron I would imagine a generous spray of some caustic oven cleaner on the part will neutralize the acid in the pores of the CI. Sodium hydroxide (lye) has long been used to clean steel and cast iron (BUT NOT ALUMINUM) car parts. Do a test on a small area first as there may be a strong reaction at first. Once all the acid is neutralized I would wash with water and dry quickly. Use a good rust preventing primer before painting.
machinejack
Active Member
Mar 27, 2014
52
Had a 1 gal plastic jug of sulfuric acid under the bench. Over time it ate thru the jug and now I have a 1 foot crater under the bench clean thru the 4" concrete. Nasty stuff these acids.
Tozguy
Feb 15, 2013
1,915
Also beware of silicone caulking tubes, the ones that smell vinegar (acetic acid).
If stored close to steel they will promote rust over time. I store my silicone tubes in heavy plastic bags.
cathead
CATWERKS LTD
Feb 7, 2013
1,065
HCL = hydrochloric acid, the name of the acid component in muriatic acid.
HCl is hydrochloric acid. The first letter in an element is capitalized and the second letter of that same element is in lower case, thus: Cl.
BtoVin83
Active Member
Aug 30, 2017
209
The rusting will not stop by neutralizing, it's the chlorine that is the culprit. There are products to pull the chlorine out of the steel. We had a customer store bleach in a bare steel tank one time, after multiple cleanings and neutralization it would start rusting again. Eventually it had huge holes rusted through the tank.
mariner3302
Active Member
Feb 27, 2015
47
I'll never let that crap near my shop again, that is a fact! I guess I need to powerwash it off the garage floor now. What a mess it will make. All because I thought I could save 10 minutes, argh...
pontiac428
Apr 23, 2018
454
Don't curse the tool for the manner in which it is used. Strong acids and bases in high concentrations do attack metals. The idea is to select and control the strength and contact time for the desired effect. Before trying to use a blast furnace to cook a hamburger patty, consider if it is the right tool for the job. If you want to give a rusted part a quick (and carefully observed) dunk in a tank of diluted HCl, it will do the job nicely. Just like your hamburger patty, you remove it from the grill just before it cooks to the pink color you like, because the meat continues to cook after it comes away from the heat. The acid will continue with a secondary reaction on an iron part when exposed to oxygen in the air that further affects your part. Neutralizing with baking soda followed by a rinse does just fine. At this point, oil, paint, or preserve your part. It will look nice!
I want to kill the rumors about never using lye (NaOH) on alloy. I use it all the time on cylinder heads after tear-down. Lye reacts with oil and water to make soap (saponification reaction), removing otherwise difficult to clean oil and coke from the heat-cycled metal. I use oven cleaner for convenience, assisted by brushes, green scotch-brite, and good gloves (any type of impermeable rubber is okay for acids and bases). Contact time is kept short and the part is rinsed often to ensure I'm not over-doing it. The resulting finish on aluminum is the same hard oxide that forms on exposure to air. I use this prep method on all kinds of aluminum parts to remove oxidation deposits, scale, grease, and coked oil. No neutralization necessary, just rinse.
These processes require supervision. You can't just drop parts in a full-concentration tank and walk away while the bubbles do the work for you, or you'll find out the hard way just how strong these commodity chemicals really are!
Another safety note, don't store your strong acids in the same place as oil-based chems... If they come into contact, the acids will quickly oxidize the hydrocarbons in the oil, which is a fancy way of saying it could cause a hot chemical fire.
mariner3302
Active Member
Feb 27, 2015
47
Very true, Pontiac! Thanks I initially thought that what I was doing was correct and safe but I was wrong. I see now that I was nowhere near prepared or informed on it's proper use which was totally my fault. I'm glad I only put it on the legs and took it off after about 10 minutes. After scrubbing the legs down with the soda ashh solution, I media blasted them, washed with soap and water and rinse. Now there is a bit of flash rust that I intend to cover with a rust converting paint. Probably Rustoleum Rust Reformer or, if not available, I'll go to Sherwin Williams who mixed the paint I will be using on the lathe.
Tozguy
Feb 15, 2013
1,915
Another lesson I am taking from your experience mariner is to beware of what can show up on utube. It is not always good stuff to imitate.
As to cleaning aluminum alloys with NaOH, check the chemistry involved and decide if it suits your purpose. It is not a rumor that lye reacts with aluminum. Lye could possibly react more readily with the aluminum than with the fouling that you want to remove. Beware of anyone who tells you different. I for one have been there done that and now avoid it like the plaque.
Using acids or alkalies is a last resort for me because of the disposal problem when done and because of the other viable options that are available.
mariner3302
Active Member
Feb 27, 2015
47
From a close friend of mine who is a chemist:
Of all the acids with which I’ve worked I dislike HCl most. The fumes not only take your breath away, but they hang around for what seems to be an indefinite period. The fumes deposit on “everything” and continue fuming albeit not in a copious cloud. This is the source of the rust and it will continue to rust if painted over, which you already know.
We used a scrubber to clean metal, which was nothing more than rollers with metal bristles un a water wash. We used caustic baths that contained wetting agents and corrosion inhibitors to remove surface oils and dirt. Phosphoric acid isn’t as aggressive on metal as HCl or nitric acids, but the benefit is that it polishes the surface of the metal. It requires longer treatment (soaking) but it leaves a smooth finish.
I’m guessing the HCl was 25 – 35%. I’m not sure how it was applied (concentrated or diluted), nor do I know how it was neutralized or for how long. Your description indicates you scrubbed it with a scotch pad. The metal “softens” due to the microscopic rust pockets in the pores. I’m not familiar with the terms “soda blasting” or “media blasting”. A better choice for removing rust would have been a salt vinegar bath or a commercially available rust remover such as Metal Rescue, but the damage has been done, so how to clean it up.
How long did you soak the leg in the acid and for how long did you neutralize it? Did you neutralize immediately after removing it from the acid (after rinsing) or did it dry out first with neutralization following later? Neutralization should be 1 – 2 times longer than the acid dip. Rinsing should take a while to ensure the removal of residual acid (unreacted) and neutralization salts. A second base dip and rinse couldn’t hurt. The part should have been thoroughly dried and then put before a fan. We would use drying followed by placement in a forced air dryer and subsequent placement in a desiccator. Without the desiccation, the part should receive a base protective coat to prevent rust. If you aren’t going to paint it, use an oil to coat the part for rust prevention. This could be removed with a caustic bath.
So, try a wire cup brush on the legs. Check with the guys at Lowes or on the website for which gauge wire is best. If your neutralization period was shorter than your acid dip, repeat neutralization, then dry and coat.
A photo of the leg would help as there are other scrubbing techniques.
Long answer, but I hope it helps. Sometimes it is easier to buy ready-made products for “consumer” metalworking because they have the wetting agents and corrosion inhibitors in the formulations.
I replied:
I used heavy duty Easy-Off and aircraft paint stripper to get the grime and paint off. Then I sprayed them with the Muriatic Acid undiluted from a spray bottle. 31.0-35.0% Source: http://www.jasco-help.com/uploads/general/Jasco_Muriatic_Acid_GJMA220_MSDS.pdf It was on for about 10 minutes when I read that it could soften and basically melt the cast iron. I rinsed the acid off for a minute of two. Then I mixed about 2 cups of soda ash to 2 cups of water then scrubbed the legs with a green scotchbrite with copious solution. I kept stirring the solution to keep it from separating. I let the solution sit overnight. The next day there was a white powder on the concrete floor of the shop. I rinsed that off and then blasted the legs with a coal slag type of sand.
After that I scrubbed them down with a soapy water solution then rinsed them off. That was Saturday. They have been hanging since. I was going to primer them with a rust remover/converter then top coat with 2 coats of a Sherwin-Williams enamel.
MrWhoopee
H-M Supporter - Silver Member
Jan 20, 2018
668
When I was in high school, one of my classmates poured liquid drain cleaner (concentrated lye solution) thru an aluminum funnel. He lost his eye.
Drano (non-liquid) contains aluminum "swarf", which reacts vigorously with the lye once you pour warm water down the drain. The bubbling action is caused by the release of hydrogen in the reaction. Don't light a match.
NortonDommi
Active Member
Nov 15, 2016
467
A 100% effective and safe way to derust Cast Iron is degrease with a detergent and pressure wash then soak in a 1:40 mix of Molasses/water.
Pressure wash after soak and repeat if necessary. After rinse treat with a Tannin base rust converter and inside you will have about a year to paint or you can oil with a fish oil which can be painted at any time.
Soaking can take a while but no damage to sound iron will occur. Bigger items can have soaked rags wrapped on them and then wrapped in plastic 'cling film'. With tape I've used this on old vehicles using duct tape.
dgrev
Active Member
Sep 14, 2017
140
Be aware that when you clean with acid you will induce hydrogen embrittlement. It is a very real risk and seemingly solid steel parts will snap like a biscuit. I even know of tank armour that was acid cleaned during manufacture that failed ballistically to stop rounds of 1/2 the diameter it was supposed to be rated at.
philip-of_Oregon
Nov 13, 2017
21
The One Thing to REMEMBER when using ANY Chemicals for cleaning, or Whatever is
"ALWAYS KNOW & have readily Available the Neutralizer for THAT Chemical".
"Always STORE them in separate areas"!
"ALWAYS KEEP AN MSDS LOG BOOK of All Chemicals you use in your work" (MSDS = Material Safety Data Sheet)
That last one should be readily Available to ALL Persons around your WORK AREA"
~~~ Philip, who spent 5 years as a 'Company' "CAL-OSHA Safety Officer" (every company over 5 employees is/was REQUIRED by LAW to have a designated CAL-OSHA Safety Officer, AND have MONTHLY Safety Meetings ! ! !
dgrev
Active Member
Sep 14, 2017
140
Phillip. A mine I worked at had one of those safety meetings every Friday morning. Management used it as primarily their opportunity to tell us all to work harder so they could make more money. We used it as an opportunity to point out the dangerous/unsafe things we had noticed. Typically 20% of what we mentioned got acted on.
Cost was the determiner.
I well remember the 44 gallon drum of 1:1:1 Tricloroethelene cleaner that they washed anything greasy in, even their hands. Luckily the electronics tech pointed it out to me when I first started on the job. He didn't know what it was, but worked on the principal that anything that had cross bones and skull on it was bad news. I got the union to research it for me and from then on wouldn't go within 6 feet of the open drip tray of the stuff.
The rest of them weren't worried when I told them how bad it was, they had used it for years and it hadn't killed them - yet.......
This was back in the mid 80s.
There is OH&S that is just bizarre (place in town has an MSDS for water!!! kid you not), I have seen people having to write essays on safe work, such as how to get out of a vehicle!!! So people get cheesed off with the stupidity and ignore all of it.
But this then trivialises the really important/real danger OH&S.
mcostello
Dec 29, 2013
407
Used to go elbow deep in a Triclor steam powered vapor tank in the 70's.
dgrev
Active Member
Sep 14, 2017
140
mcostello - the difficult part about exposures is that everyone is different. We have all heard the stories of someone who smoked from the age of 5, lived into their 90s and probably got run over by a bus.
You could be one of the hardy souls who have a higher tolerance of it.
Everything to do with exposures tends to follow the bell curve probability. I will attach a graphic. In short, the majority of people tend to fall into a certain range, which tapers off at each end to the exceptions: the ones who have almost zero tolerance and the ones who seem almost immune.
<http://www.statisticshowto.com/wp-content/uploads/2013/09/standard-normal-distribution.jpg>
As you can see, -2 to 2 standard deviations covers most people.
I was involved many years ago with having to isolate and dispose of an industrial product. I had been warned it was dangerous but could not find out anything about it. When I questioned the company concerned they responded with words to this effect "25% of the people exposed to it occupationally it would kill, the other 75% seemed unaffected, but there was no medical test that could identify which group people were in, so it was banned".
This is also the reason so many promising medicines that we hear about on the news never get to be sold.
However, I have really taken this off topic.
Getting back on topic, if you have patience, a molasses and water tub is a very good way to de-rust steel BUT only mild steel. It will ruin spring steel, alloy etc. The purer the water the better the result. Being able to cover the container is also preferable, the smell is pretty impressive. I can't tolerate the stuff on my skin, gives me migraine headaches!
They always used to say that Phosphoric Acid was the least harsh of the acids for cleaning steel and that it left an anti-rust phosphate coating on the
steel when rinsed off gently.
Jidis
Active Member
Jul 29, 2017
39
I have a feeling that might have been me if you read it in an electronics forum or something. I can't rule out humidity's involvement, but I still blame the acid for that one, and still have stuff that needs to be cleaned up. The MA has been outside and far away ever since. I hope it's OK in this heat.
owl
Active Member
Mar 15, 2012
94
You can cure hydrogen embrittlement if the part is not yet cracked. I believe that putting the part in a 350 degree oven for a couple of hours will do the job.
dgrev
Active Member
Sep 14, 2017
140
Thanks for that, I have never seen that mentioned before.
[6]
[5] [7]
