Hey, great work on your first thread of multi starts.
Regarding methods of clocking the other treads start. The method I was taught was to utilize the change gears. If you have a 120t idler, revolve the chuck forward until the stud gear's key way is at the 12 o'clock position, remove the stud gear, revolve the 120t idler its normal direction a tooth count a division of 120, slide on the stud gear back and tighten its retainer.
Now you can cut 1, 2, 3, 4, 5, 6, 8, 10, 12, 15, 20, 24, 30, 40, 60, and 120 start threads.
<<Self correction>> This only works simply if the Stud and Screw gear are Equal.
