The recommendations are accurate. Don't use a catalog as a wish book, there are hoards of nonsense devices that trigger 'Igottahaveone' just like impulse purchases in retail. Many are little more than toys; impractical, flashy, whose only purpose is generate profit to seller. None of that s**t existed in the past, and "we" machinists got along fine, turning out incredible work. The basics are dependable, and the real foundation [but hidden] behind silly tricks.
Simple shopping list. Write down every thing we've listed, put a hash mark when they are mentioned again. whatever collect the most marks, start there. Do not think a box full of goodies makes you a machinist.
Starting out, a DRO is not critical, might even be a hindrance. Develop as a machinist, not an operator. Learn the trig, use simple algebra and tolerancing so they work for you, not hidden in a mysterious electronic display.
Want to keep track of multiple table positions? 2 strips of masking tape; 1 on the table, another short piece directly adjacent on it's mate. Use a fine point ink pen, mark a line at your position 7.562 whatever, write that at line and set dial to coincide. Your mill probably has .200 dials[one rotation = .200 travel] the dial at .162 [both 1 an 5 are odd]. 7.618 will read .018. You will watch those lines approach, then look at the dial, and position as fast you can read, without overshooting common with DRO's.
