- Jan 22, 2011
- 8,031
That's factory. It's a "silent chain", built about the same as a timing chain.
Thanks for the reply Ron, I'm excited about using it. Here is my attempt at sending picsView attachment 37361View attachment 37362View attachment 37363View attachment 37364[If I was to go to v pulleys, anyone know the rule or formula for figuering combinations of step pulleys so you could you use the same belt?]
what a nice machine no signs of ever rusting, and seems to be well cared for
I have never seen one like that... but it sure looks factory
I would save all the parts it may be a rare find
steve
Hello all, I just purchashed a very old South Bend Model A 9" lathe. Still being new to machining, I felt I had to have it. The best I could tell, it is a 1935 series, belt driven, tool room, with a 3 1/2' bed. It has the old style quick chage gear box, with one gear selector in front, a 3 position lever on top & and a push/pull knob on the side. The motor is an old 1/4 hp, Westinghouse motor, which is chain driven to a single sprocket, which is at the end of the 3 step pulleys on the jack shaft, then to the headstock. This will only give me 3 speeds in high range, and three in back gear. For someone starting out, is this sufficiant speeds for general work (alum and mild steel), or should I be looking for a different motor set up with a 2 speed step pulley? Any other info on this lathe would be appreciated. Thanks, Jim.
Jim, there's a thread here some place where a member replaced his dials with larger ones. It's buried somewhere. I'll try to find it.
http://www.hobby-machinist.com/showthread.php/5772-big-dials?highlight=larger+dials
That's a start in the right direction.
