My New Stirling Alpha Ross 38 Cm3
atlas ten
Nov 17, 2014
172
Cool. Didnt know stirling engine made cold when driven.
Jack
Sent from my SGH-I337M using Tapatalk
Chip Hacket
H-M Platinum Supporter
Jul 12, 2015
190
That is a great engine. What is the flywheel diameter? Also why is one piston sleeve brass and the other not? I think Stirling engines are so cool.
Titou16
Sep 2, 2013
39
Thank's
The flywheel diameter is 108 mm. The cold cylinder was in brass because I had not yet made a new one in cast iron. The first version of the engine had both cylinders in brass and both pistons in aluminium with quadring seals, but it didn't work well. When I made the hot cylinder and the hot piston with cast iron, this was much better. And finally I made the cold cylinder and his piston in cast iron and this time it works very well.
AdBlock Detected
I've Disabled AdBlock
