Joe,
Everything appears to be right. The problem must be in the turner. Is the rotation of the turner loose or tight? The next area would be the bit itself. Is it HSS or carbide? It appears that there is a good amount of overhang of the bit from the radius bow? You might try swinging a pass on a piece of scrap with less overhang to see if the finish improves.
I just built one of these same radius turners with the casting set. It is way too loose and leads to same issues as the original post. I just couldn't get it to hold the rigidity it needs.
I am going to build another setup like this on youtube:
