- Jan 29, 2014
- 64
Because my first lathe, also a mondiale, has some problems at the spindle. I needed something else to be able to turn metal.
I found a other Mondial lathe with a vario. It is based at the early simplex lathes like mine but gear changes can be done with a vario brom about 27 rpm to 900 rpm.
This lathe was in pretty good condition but needed some repair work.
It is redy to use now.
Here is a picture in the early repair proces.
The lathe came with the compound rest welded. This was done because the screw was missing its nut.
This means that I had to fabricate a new one.
It was a trapizoidal tread of 13x2.5 mm. Since this was not a standard size it looked that I had to fabricate it myself.
But then I found a tap set for it , used but still in good condition and only for 10 Euro.
So the nut was made in no time and the compound is working again.
Here are some pictures.
The toolpost on top of the compound needed some repair to.
Somebody made one side bigger so he was able to mount a bigger tool. The haccking was apparently done with a grinder. That spot was flattend with the mill.
At the under side of the toolpost are some cuts that coorespond to a pin so it is more easy to put the toolpost at a 45° or 90° angle.
The part that was in the compound was broken and I made a new one, hardning and all.
Then the lathe got a good cleaning to get rid of al the smudge that builded up over the years.
While cleaning I noticed that the wiring was al rotted from the oil.
So I changed al the wires and installed a Thermical conductor.
Now the lathe is ready to be installed at the places where my other lathe is standing.
Here are some pictures of the lathe now.
I can't wait until it is in place.
